You can find a "Voltage Regulator" in Mexico that they use in many businesses there. You may have to order but only takes a couple days to get one. Some Ferreterias carry them or can get them. We bought ours a few years ago and it has worked fine. One for each leg so wiring it to feed two legs may require an electrician - they do not come wired to plug in. But this device corrects not only low voltage but high voltage. These are the only ones I have ever found and they can only be found in Mexico to my knowledge - I once saw one on ebay in the US for a ridiculously high price. I am thinking we may have paid around $300 but not sure.
ISB Voltage Regulators
http://www.isbmex.com
Líder en el mercado mexicano, por su amplia gama de reguladores de voltaje tanto industriales, tipo computadora como domésticos que ofrecen una protección adecuada a sus equipos
Leader in the Mexican market for its wide range of voltage regulators, both industrial and domestic computer style offering adequate protection teams
http://translate.google.com
COMPENSADOR DE VOLTAJE CVR es un regulador automático diseñado especialmente para mantener niveles óptimos de voltaje para aquellos equipos que inclusive utilicen un motor de corriente alterna que están dentro de la capacidad del compensador; protegiéndolos contra las variaciones severas de tensión del sistema de suminisro eléctrico.
VOLTAGE COMPENSATOR CVR is an automatic controller specially designed to maintain optimal levels of voltage for equipment to even use an AC motor which are within the capability of the compensator, protecting them against severe voltage variations of electrical suminisro system.
El CVR lleva a cabo su funcionamiento mediante dos pasos de elevación y uno de reducción del voltaje de entrada. Esto se realiza por medio de un autotransformador y un circuito de control que mantienen el voltaje de salida en los niveles seguros para la correcta operación de sus equipos.
The TRC carries out its work through two steps of elevation and a reduction of input voltage. This is done by means of an autotransformer and a control circuit maintaining the output voltage at safe levels for proper operation of your equipment.
Es un dispositivo electromagnético que consiste en un transformador de potencia y un circuito electrónico de control, el equipo está operado por un microcontrolador que da como resultado un producto muy confiable, eficiente, rápido y de alta precisión en su operación. Construido con los mejores materiales y un proceso de manufactura muy especializado, un equipo que puede operar ininterrumpidamente por mucho tiempo y que no requiere mantenimiento. El CORRECTOR DE VOLTAJE está diseñado para mantener un voltaje estable en una instalación eléctrica del tipo usado en casa habitación. El CORRECTOR DE VOLTAJE provee un voltaje adecuado para alimentar refrigeradores, lavadoras, alumbrado, equipo de bombeo, planchas, aire acondicionado y todos los equipos que tiene en su instalación eléctrica, aún en líneas tan bajas como 87 V~ y desde una operación sin carga hasta 60 A para el modelo 8000 VA y 30 A para el de 4000 VA.
Is a device consisting of a power transformer and an electronic control circuit, the computer is operated by a microcontroller which results in a very reliable, efficient, fast and highly accurate in its operation. Built with the finest materials and highly specialized manufacturing process, a team that can operate continuously for a long time and requires no maintenance. The VOLTAGE CORRECTOR is designed to maintain a stable voltage in an electrical system of the type used in household. VOLTAGE CORRECTOR provides the proper voltage to power refrigerators, washing machines, lighting, pumping equipment, irons, air conditioning and all the equipment you have in your electrical system, even as low as 87 lines V ~ and from a no-load operation up to 60 A for Model 8000 VA and 30 A for the 4000 VA.
CARACTERÍSTICAS MÉCANICAS POR MODELO
• Gabinete construido en lámina de acero de gran robustez mecánica, con acabado en pintura especial a prueba de intemperie.
• Tablilla de conexiones para entrada y salida en ambas capacidades.
• Cuenta con soporte para montaje en pared.
• Indicadores luminosos de operación en la parte frontal del equipo.
MECHANICAL FEATURES BY MODEL
• Cabinet constructed in steel sheet of high mechanical strength, special paint finish, weatherproof.
• Tablet for input and output connections in both capacities.
• It has support for wall mounting.
• Operation Lights in front of the computer.
Recuerde sea cual sea su voltaje de línea de entrada, usted tendrá un mejor voltaje a la salida del corrector, por ejemplo:
ENTRADA V~ 85 90 95 100 110 120 135 140 145 150 155
SALIDA V~ 103 109 115 121 121 120 121 125 130 134 139
Remember, whatever the input line voltage, you will have a better output voltage corrector, for example:
INPUT V ~ 85 90 95 100 110 120 135 140 145 150 155
OUTPUT V ~ 103 109 115 121 121 120 121 125 130 134 139
VOLTAGE
IN = OUT
85 = 103
90 = 109
95 = 115
100 = 121
110 = 121
120 = 120
135 = 121
140 = 125
145 = 130
150 = 134
155 = 139
CORRECTOR DE VOLTAJE 8000 - 4000
Regulador Electrónico, mantiene estable la energía eléctrica y cuenta con supresor de picos
VOLTAGE CORRECTOR 8000 - 4000
Electronic Throttle, stable electricity and surge has
MODELO 4KVA 8KVA
Ancho A 29,0 cm 38,0 cm
Fondo B 21,0 cm 24,0 cm
Altura C 25,5 cm 29,2 cm
Peso 12,7 kg 18,9 kg
MODEL 4KVA 8kVA
Width A 29.0 cm 38.0 cm
Fund B 21.0 cm 24.0 cm
Height C 25.5 cm 29.2 cm
Weight 12.7 kg 18.9 kg
ESPECIFICACIONES ELÉCTRICAS
ENTRADA
Voltaje de entrada 127V~+15, 7% -33%
(85 a 147 V~)
Frecuencia de entrada 60± 3 Hz
Sistema monofásico 4KVA(4000 VA)/ 8 KVA(8000 VA)
(*) Factor potencia 0,98 mínimo
(*) Eficiencia 99%
SALIDA
Voltaje de salida 102 a 129 V~
* a plena carga y a voltaje de línea nominal
ELECTRICAL
INPUT
Input Voltage 127V ~ +15, 7% -33%
(85 to 147 V ~)
Input Frequency 60 Hz ± 3
phase system 4KVA (4000 VA) / 8 KVA (8000 VA)
(*) 0.98 Minimum Power Factor
(*) 99% Efficiency
OUTPUT
Output voltage 102 to 129 V ~
* a full load at nominal line voltage
VOLTAGE
IN = OUT
85 = 103
90 = 109
95 = 115
100 = 121
110 = 121
120 = 120
135 = 121
140 = 125
145 = 130
150 = 134
155 = 139
The ISB devices cannot provide more amps than the breaker to the parking space allows. You cannot get more from the outlet than the wiring provides for. So the ISB devices have potential but cannot improve on the electricity provided. What the ISB device can do is provide better voltage. It will not make a 15amp circuit provide you with 30amps. But if the outlet is capable the ISB devices are good up to these ratings…….
4000VA @ 120VAC = 33.4 AMPS
8000VA @ 120VAC = 66.8 AMPS
I do not think there are any parks in Mexico where more than the 4000VA ISB device might be necessary.
