I have read stories for a decade but only met one person who had a real problem. And I have met thousands of RVers in the past 10 years. I have no doubt it happens in certain places but I do have my doubts it happens in 98% of Rv parks.
I agree it is probably far from 98% - but the numbers are not low. I can tell you quite a few where I have rewired myself.
That park a lot of people have been to in Chetumal had almost all plug ins with wrong polarity with bad grounds and I spent several hours with the manager showing him how to fix it.
The old La Siesta in San Miguel de Allende had loose wires hanging out all over the place with no covers on outlets.
In Matehuala I think I have tested every outlet and only found a couple with proper polarity - not to mention ground.
I could go on. I have never gotten fried or lost equipment due to faulty wiring because I always check.
One new RV park we have been to a few times has 6 gauge wire coming into the main breaker panel - to service some 20 RVs. Then they have two circuits using #6 going out several hundred feet on either side with every other RV on one circuit and then the other RVs on the other circuit. One day a few too many appliances and the wires in the breaker panel melted. (no names).
We see this sort of thing all over. We keep a volt meter plugged into an outlet in our RV and can watch the needle going up and down as people turn appliances on and off.
Yes, there are many RV parks that are OK but there are also those that were wired by someone who had any actual knowledge of electricity.
I tried to find some wire size charts online to Copy & Paste here but came up with very little useful stuff. Wire has resistance so when there is a long distance from the breaker panel the wire size must be increased to make up for the loss due to distance. So in SOME parks we have been in they use wire that is too small - they try to run it to quite a few spaces when maybe it is only enough for one space - they run long distances without increasing wire size. There are formulas and calculators for all of this. A wire can only carry so much. Size and distance reduce useful power. Too many spaces on same circuit means too many users could overload the system.
Here is a simple little sort of chart I found - lots of more complex ones can be found online.
Low-voltage Lighting and Lamp Cords 10 Amps 18 Gauge
Extension Cords 13 Amps 16 Gauge
Light Fixtures, Lamps, Lighting Runs 15 Amps 14 Gauge
Receptacles, 110-volt Air Conditioners, Sump Pumps, Kitchen Appliances 20 Amps 12 Gauge
Electric Clothes Dryers, 220-volt Window Air Conditioners, Built-in
Ovens, Electric Water Heaters 30 Amps 10 Gauge
Cook Tops 45 Amps 8 Gauge
Electric Furnaces, Large Electric Heaters 60 Amps 6 Gauge
Electric Furnaces, Large Electric Water Heaters, Sub Panels 80 Amps 4 Gauge
Service Panels, Sub Panels 100 Amps 2 Gauge
Service Entrance 150 Amps 1/0 Gauge
Service Entrance 200 Amps 2/0 Gauge
