Tequila
Jun 04, 2018Explorer
traffic lights meltring
Those new LED taffic lights that we are seeing lateley are melting in the latest heat wave. Mexico news daily had a photo of one that looks like something out of a Dali painting.
MEXICOWANDERER wrote:
The municipio for BCS purchased 400 streetlights a good brand CREE. Weak 9 watt output. These were well made lamps.
Street lighting is in it's infancy. The so called engineers who are designing what I see insist on using Fresnel lensing which is expensive, unneeded and just plain shows their lack of experience of using a flat platform COB device.
The following chip will blow a 70 watt high pressure sodium street lamp into the weeds. Pure floodlamp effect.
I made a tunnel-type shaded 100 watt streetlamp to cover the crosswalk across a federal highway the light was contained so it did not bother drivers. It was said the children never again had problems or close calls when using the crosswalk after the bus left them off 2nd shift.
You may have overlooked the STREETlamp part. Regardless of anything else the lamp's actual output meaning what you see on the ground is considerably weaker than the 40 watt low pressure sodium lamps they replaced.
Here's some comments :)
IMHO CREE makes by far the most efficient LED chip on the market.
But a 10 watt ROYAL or SHARP chip puts out far more light than the CREE. What's up? The CREE is being underdriven at 6 watts presumably to increase life span.
There are two diameters of common traffic light -- the smaller operates on 11 watts. 12" lamps require 15 watts.
Newer polyethylene signal light bezels are definitely made in Mexico. RAMFA Co Reynosa.
Being an engineer with a full test bench I get to play with this stuff.
Non repairable street lamp modules can be made for far less money if they are epoxied. The new lens are NOT pyrex and when vandals break the lenses there is no way to fix the lamp. Chew and spit stupidity. Four and a half pounds of aluminum for recycling...
The bases down here are not designed well. Aluminum used as a radiator should always be black anodized HARD anodized. 35% better thermal conduction and radiation. The driver should have it's own heat sink interface and be bonded to to the fixture. Next year I will enjoy a 50 watt array of 12 lamps operating 24/7 for year no 10. Critical p/n junction temp reduction results in a vastly greater emitter lifespan. Optimum tradeoff can result an easy 20 year lifespan but it costs money for heatsinking and design integrity.
Meanwhile back at the ranch I love the new semafores. Same for the mobile traffic control (desviacion) sign boards. They need 9 volt solar panels to discourage theft.
