judelaurenzo25g's avatar
Jan 09, 2018
1000w inverter install
Hi All,
After doing some research online and here on the forum. I'm going to be attempting to install a 500-1000w inverter to watch TV when dry camping.
I will be installing it within 2-3 feet of the battery compartment. I was planning on using 1/0 Gauge cable with 180 Amp ANL Fuse.
My questions are:
Is the 1/0 gauge the correct wire size?
Should I use 180amp fuse or circuit breaker? Is the 180amp to much?
Do I need to add any other safety measure between the inverter and battery?
I'm open to any suggestions regarding, inverter, wire, fuse or breaker size. I just want my family to be safe. Let me know if I overlooked anything.
Thanks,
JL
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,393 PostsLatest Activity: Oct 03, 2025
