Acampingwewillg's avatar
Acampingwewillg
Explorer II
Jul 03, 2023
12 / 24 volt air conditioner
Ok....so with so many boondockers going the mini split route to run air conditioning off batteries but on those not nights when you pull off the road or into a rest area and you don't want to run the generator, what's the latest thinking on the abundance of low volt airs.
I'm planning on 2000 watts of solar roughly and a separate lithium battery bank separate from my starting lead acid battery. Heck, I don't know know how I'm going to work at all the specifics but plopping a 12/24 volt air into a vent opening instead of a mini split sounds much easier. Just browsing Amazon, they show quite a number of low volt units? I just haven't heard much in regards to function?
  • Kept in mind if you go with a lower btu unit, it will run more.
    So if a 15k btu runs 25% of the time a 5k btu will run 75% of the time...net result is the same number of Amp hours used.
    While it's possible, it gets expensive compared to just breaking out the generator. Those that jump thru the hoops usually live with limited use.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    physics is the limitation, Even if the efficiency is double a conventional rooftop which puts it in the ballpart of high efficiency home units, your still looking at near a 50A draw from 12V, 24V would be around 25A, more tolerable.
    If the efficiency is near that of todays RV AC units, double those numbers
    Typical RV AC unit at 12A draw is about 1500W=4500BTU AC output is 13K BTU so your running about 3:1, or an Engergy efficient ratio of about 10. (BTU out/wattsin) which actually is a meaningless number, the units don't match. It should be BTU out/bTU in, but then the number is 3x less.
    That aside the top AC units approach 20 for a EER, and that still puts you in the 50A range from 12V.
    A quick look at the amazon units claim decent efficiency, 750W for 13Kbtu vs the 1400W for a rooftop RV, but still that's around 25A at 24V and it requires 50+A for startup.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Mar 11, 2026
