mtCoder's avatar
mtCoder
1977 Terry Renovation
Hey guys,
The wife and I just bought a 1977 20' Terry travel trailer that we are planning to renovate. The outside is in good condition, but there are several places with water damage and whatnot so we plan to pretty much overhaul the interior. So far, we have pulled out the cabinets and kitchenette, ripped down most of the walls and ceiling, pulled the stove and fridge. Unfortunately, the trailer is just too tall to fit into the shop, so this is all being done outdoors and we will be at the mercy of the weather. Because of this, the plan is to keep the skin on as much as possible while working from within. Has anyone here done this before? We will need to be replacing several pieces of framing because of the water damage (although much of the roof is good just not around seams), and are unsure of how to attach to the exterior without removing the skin. Could we use liquid nails to attach the new frame where the old was attached with staples from the outside?
Also, anyone have an idea how to replace the bottom board supporting the wall? The area around the wheel well is shot and will need to be replaced.
Thanks!
EDIT for wheel well photo:
Moderator edit to re-size picture to forum suggested limit of 640px maximum width.
  • Do a search on Youtube for RV sidewall repair or fiberglass repair you will find a couple of how to videos.
    Good luck with your project.
  • Looks like a "skin off" job to me. Get a large blue tarp to cover when not working and when weather does not cooperate. Do it right, or figure when you can do it again. JMHO!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 03, 2026
