DrewE
Oct 15, 2019Explorer III
It looks to me like there would be space to construct a two storey battery box on the trailer tongue. That's what I would do (and have them always all connected).
With a switching arrangement, you'd in essence be just swapping batteries in and out, so whichever one is active would be active for the loads, the converter, and the solar charging, and the other would be sitting entirely disconnected, assuming you wired all the loads and such through the selector switch. If you had the inverter or whatever bypassing it, it would of course only use the battery it's connected to regardless of the switch setting. (An exception would be the 1+2 setting, which connects everything to everything else.)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
