michelb
Jun 10, 2013Explorer
We have 98 PA which I believe has the same opening as yours which unfortunately is not huge. We camp for several weeks without hookups in the summer so I often remove the CRT and simply put a 28" LCD in it's place. It's not perfect and the TV does stick out past the edges but it does the job and takes a lot less battery power. To hold it down, I actually use the same clamps (front wood one and rear metal one) that hold the CRT but I believe I had to redrill the rear one to fit around the base of my LCD.
If I find a picture of it somewhere, I'll post it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
