riah
Dec 18, 2020Explorer
jeglenn wrote:
24v sounds like a bad idea. Why not two 12v batteries in parralel instead?
I was thinking that it would be less expensive to wire as well as the LiFEPO4 battery is less than 2 12V LiFePO4 batteries - but it sounds like we should just stick to the 12 V setup as that's what the system is designed for originally and it would be the most straightforward seeing we are only looking at 400 Watts of solar currently. Thanks for the reply!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
