phemens
Dec 19, 2020Explorer
The one variable you didn't include in the SiO2 batteries is weight. They weigh as much as lead acid batteries, if that is part of your consideration. OP didn't mention that as a factor, but should be aware of the difference. Weight is the primary reason I went with LiFePO4.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
