FWC
Dec 29, 2020Explorer
If you actually want to use the full capacity of your battery you need to deal with the absorb phase every charge.
Furthermore you will greatly decrease the life by not performing a full charge. Say you plan on using 80% of the capacity of your battery, with a full charge you will cycle between 20% - 100% SOC and should get about 1500 charge cycles. If you stop the charge at the end of the bulk phase, you will be cycling from 0% - 80% SOC and only get the mythical 628 cycles out of your battery. Which would you choose?
pianotuna wrote:
FWC yes, with SiO2 you have to deal with an absorb phase, once every 30 days. I'm sorry you see that as such a hardship.
For those of you who really want Li at an extremely competitive price surf here: https://ablithium.com/
$400 for 100 amp-hours, drop in with BMS. Plus shipping.
My own opinion is that SiO2 have never caught on due to their high price. Some how Li has circumvented that.
As to Li such as battlebord, they are really a 120 amp-hour battery with a BMS that cuts off the bottom 20 amp-hours. I wonder how that will work out as the batteries age.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
