theoldwizard1
Aug 22, 2020Explorer II
corvettekent wrote:
Since both are lead acid batteries the solar should not make any difference.
My experience is the flooded acid will last longer than AGM as long as you maintain the flooded acid batteries. I check mine 3 or 4 times a year.
I would add, flooded lead acid should be checked more often if they are heavily discharged or charged.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
