Groover's avatar
Groover
Explorer II
Jun 03, 2019
240V from 120V generator
I would love to be able to use the 6KW quiet diesel in my motorhome as a backup generator at the house. One problem is that the house needs 240V while the generator makes 120V. I have not had good luck finding 120V to 240V transformers. I am not an electrician but I remember something about isolation transformers changing the phase of the current but I don't remember if it is 180 degrees which is needed to make to 240V or only 90 degrees. Anyway, is there anyone out there with experience on this that has a good solution? I would like to be able to supply 4kw at reverse phase in case the load is off balance in the wrong direction.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Mar 02, 2026
