stacaz822's avatar
stacaz822
26-28 inch 1080P smart flat screen TV with audio output
I have searched online but can't quite find what I am looking for. Please comment with suggestions for a good flat screen Smart TV 26 to 28 inch diagonal(with tuner and audio outputs, and mounting option).
Thanks! I don't have many options here. Just looking for smaller size flat screen with a TV tuner and some sort of audio output to connect to amp and then to ceiling speakers.
  • I found several on Amazon using "28 inch tv 1080p" as search criteria. Even found a few 12v with audio out. I would include links but there are too many that might be what you're looking for to list. Several have audio out, and are Smart TV's to boot.
    Thanks!!
    At that size I doubt you find anything other than sub $150 toss-aways. Most will have audio outputs, but almost assuredly not an optical audio out. I would think all would have standard mounting taps on the rear case. I don't have any idea as to the resolution, but on a screen that size it probably won't make much of a difference. The other thing you may not find is the "Smart" TV option. I am sure it adds to the cost of the Television and probably doesn't fit into the marketing strategy of the manufacturers which is build the sub big screens as cheap as possible so the sellers can have that price leader.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 22, 2026
