time2roll
Jun 26, 2013Nomad
The hard part is pulling new 6/3 romex from the cord entry to the new 50a breaker panel. If that is easy access then go for it.
27 amps continuous is on the high side for 30a service. Technically you should limit continuous (3+ hrs) amps to 24 (80%) on 30a supply. Is that two air conditioners running?
Some break out one air conditioner and plug into the 20a GFI direct.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 25, 2026
