hershey
Jun 27, 2013Explorer
I have a 30 amp RV.
When 50 amp is available and I feel the need, I just plug the shore power cord into the 50 amp supply with the dogbone adapter
I plug another 10 ga extension cord into the 30 amp supply with a dogbone adapter to 20 amps. The 110 power to my converter/inverter is split with plug and socket. I plug the converter/inverter into the 30 amp supply cord.
The Converter/inverter supplies independent power to my washer dryer, microwave, water heater, TV console are and a couple wall outlets. The rest of the AC supply takes care of everything else including the 2 AC's with also are part of the Energy Management System.
This has worked extremely well for the last 8 years of fulltiming.
I can run both AC's and they don't even cycle because there is no other measurable draw from their circuit.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 25, 2026
