pianotuna
Aug 31, 2016Nomad III
4x4van,
I'd wire it so that everything you wish to run on an inverter would be on one leg, and everything else on the other leg. Exception the OEM air--simply refrain from running it on the inverter. This gets around having a 2nd transfer switch for an inverter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
