portscanner's avatar
portscanner
3d printed wall plate for usb charger
This is not a new design of mine, but this is the first time I posted it. I wanted to add a USB charger outlet to my RV. Cutting a clean, neat hole with flat sides is very difficult. So, I designed a single gang plate that would hold a 12V - USB charger. I created this some time ago and I am just posting it now. If you have a 3d printer, you can download it from here:
https://www.thingiverse.com/thing:3411192
The first time I did this I used a low voltage single gang mounting bracket because I had room in the wall. This time I dont have the room so I will be using a surface mount box.
The usb charger I am using is from Amazon
https://www.amazon.com/gp/product/B00MNGCDVS/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
You can also use this plate for any device that uses a round hole with flat sides where the diameter of the round part is 28.3 mm and the flat parts are 26.3 mm apart.
I will install it this weekend - pictures of the install when I get it done.
  • portscanner wrote:
    bob213 wrote:
    Thank you. Please...keep posting your designs. For the average guy who wants to get into 3D printing what printer would you suggest?
    This looks like it would work perfect for this voltage meter!
    meter
    bob213 - I sent you a PM.
    is there some reason we can't see your recommendation?
    bumpy
    meter
  • Thank you. Please...keep posting your designs. For the average guy who wants to get into 3D printing what printer would you suggest?
    meter
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
