overhill7's avatar
overhill7
50 amp cord end
Recently purchased a used 50 amp cord to use as extension.
Thought I would test it before hooking to rv. With a test light either the ground or the neutral will light the light on either hot side. Is that normal?
  • Yes, perfectly normal as the neutral & ground are bound together at the main panel. :)
  • That doesn't seem normal. Is this cord a factory made cord with the ends molded to the cable? Are both ends configured to the same type plug, in other words, can you plug the one end of the extension into the other end? If so, there is something wrong.
  • Yes, normal because Neutral and ground are connected together back at the main panel.
    Cheers,
    Scott
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 29, 2025
