VintageRacer
Jun 02, 2014Explorer
Recommending a wire size when you don't know the current is hit or miss. Yes, bigger is always better but if the OP can estimate his load he can then decide on a wire size that is going to work well for the application. In my bus I connect my batteries with 2/0 because I have an inverter that can pull some current, in my truck camper I use 6 gauge because the only thing I run is some lights so the charger is actually the highest current.
Brian
Brian
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
