rrwantr's avatar
rrwantr
7 feet between 6 volt batteries in series?
Looking to upgrade to two 6 volts. Can't fit a double box in the area my single 12 volt is. Would it be ok to locate one on one side of the camper and one on the other with the batteries wired in series appropriately. So there'd be 12" hot to the first, about 8' between the negative and positive of the 2 batteries, and then 8' return from the negative of the 2nd battery.
And would be looking to put on portable solar.
  • Hiking Hunter wrote:
    Yes, there is a huge difference. I'm suggesting #4 because it's a practical wire diameter for commonly available connectors. 4/0 is about the size of your thumb and is not practical to work with. In a short run such as this there is not a significant difference in the resistance between the two.
    There is a five-fold difference between 4 AWG and 4/0 AWG, in resistance. I would recommend at least 2/0. If there is anyway to get the batteries closer together, I wouldn't locate them at a distance of 8'.
  • Yes, there is a huge difference. I'm suggesting #4 because it's a practical wire diameter for commonly available connectors. 4/0 is about the size of your thumb and is not practical to work with. In a short run such as this there is not a significant difference in the resistance between the two.
  • You'll lose a little efficiency, but not much. This wouldn't be any worse than longer battery cables to the pair.
    Use as large of wire as possible and you'll be fine. I'd suggest a #4 if practical.
