stevenal's avatar
stevenal
Nomad III
Sep 29, 2024
Solved
The batteries killed my Happijac remote
Expensive electronic device ruined by leaking AAs, sigh. I guess I will now be pulling the batteries between uses. Only 6 screws need removal. Are you listening Lippert? Please make the batteries more easily accessible, or use a button cell.
  • I've had Duracells leak
    I've always used Duracells, but they also leak.  Supposedly Energizer has a “No Leaks Guarantee”.  Lithiums also won't leak, but they are more money.
    • stevenal's avatar
      stevenal
      Nomad III
      I kept the old controller, thinking I might harvest the holder and connect it remotely. Only a bit of removable corrosion on the holder.
    • stevenal's avatar
      stevenal
      Nomad III
      Not more than a new control, or time spent on the mods I was considering. Lithiums are on order. Thanks for the idea.
  • I've recovered many devices after the batteries leaked. Since the batteries are alkaline and not an acid (like in the car) you need to neutralize by using a weak acid. I just sparingly use some q-tips and white vinegar. Hold the device so gravity keeps the mess from flowing deeper into the electronics and dab on some vinegar.  After a few seconds use another q-tip and wipe out the mess. Repeat a few times and hopefully you can save the device.
    My thoughts:
    Less is more. Just dab the vinegar from the q-tip, you do not have to get things too wet for it to work.
    Almost every battery that leaked was a Costco Kirkland AA or AAA so I will never use those anymore. I just buy the Duracells from Costco for a dollar more.
    You might have to carefully disassemble the part to do a better cleaning. Just be careful and don't break any solder joints.
    • stevenal's avatar
      stevenal
      Nomad III
      These were Duracells. I used a Dremel wheel to clean the contacts, water and q-tips to clean up the liquid, and finished with a hair dryer. With new batteries, I was able to extend the jack I was working on. When done, the jack would not retract even after resetting things several times. Synced up a new control, and things work again.
