bid_time
Jun 03, 2024Navigator
First of all, I can’t discern what you are talking about. I don’t know if you’re talking about the house battery or the starting battery (or both). One is recharged by the converter, the other is recharged by the engine while running (depending on the configuration of varies switches/relays). So I don’t know if I should direct you towards the alternator or the converter. But you could help yourself in diagnosing the problem(s) by testing the output voltage and amps of the alternator and converter with a test meter put directly on the output terminals of both (and the input terminals of the converter).
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
