Oasisbob's avatar
Oasisbob
A.C. PLUG ?
Wanted to add one aditional A.C. plug to the interior of my HTT runnin off an existing plug. I was stopped in my tracks, and a bit baffled, as to how to get into the factory plug. Seems to be sealed in a white plastic cube on back side of plug. How does one get into this? Honestly I feel a bit stupid but.. Is it made by the rubex cube people or am I a dim bulb? Merry Christmas
  • Can he not just cut the wire to the existing RV type outlet then splice in a new normal house type receptacle with box as space allows?
  • These receptacles are the same or at least very similar to what is in mobile homes. I have replaced a bunch of them with standard 110 receptacles, but there is usually some slack in the wires on a mobile home. If there is some slack in the wire and enough room ( depth ) you may be able to install a shallow ( remodel type ) box and a standard 110 receptacle to feed your new receptacle.
  • I'm not sure what you are attempting to do.
    This is a plug;
    This is a receptacle;
    Are you wanting to add another receptacle daisy chained from an existing receptacle?
    RV and mobile home receptacles are enclosed and don't need to be in an electrical box. The typical receptacles in a house must be enclosed in an approved electrical box. Usually the RV receptacle must be pried apart.
  • RoyB's avatar
    RoyB
    Explorer II
    The low profile plastic 120VAC RV receptacles are designed to be placed in tight quarters and use the pinch type wire connections. The ROMEX is not cut off like the standard type 120VAC wiring boxes but stripped back and just layed into the fixture. Then we you press it all in place the knife type holders cuts thru each wire and makes contact. This will allow another daisy chain 120VAC receptacle further down the zone. These are not intended to be used as a junction point for additional receptacles.
    Another thing to look out for is when these type of receptacles are used a small crease is put on the cable wiring and if you move it, it easily may break into. Then you gots more problems
    If you have enough space you might replace the pinch type 120VAC receptacle for a PVC junction box and use a standard 120VAC house type receptacle with screw terminals. The problem of course is going to be finding enough slack in the presently used romex to do this.
    Check in with LOWES electric dept and look at all the 120VAC house type items you can use to install another 120VAC receptacle
    You may have to install a PVC junction where you have some slack behind your cabinet and install another 120VAC circuit using twist-on wire nut connections
    Roy Ken
  • No, you should not feel that way. Campers are made from the inside out. All the screws are installed from the outside. The last thing to go on is the outer "skin", and then nothing is accessible without tearing something up. Cabinets, plugs, everything.
    If you can find an exposed wire, inside a close space, you'll probably do better tapping into the wire there, than going through the plug.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
