SDcampowneroper
Feb 06, 2017Explorer
I have had propane 'grease' build up in the pipes. On the one instance in very cold weather it was from a very old 100# tank that had not been used in many years. It plugged up stove, furnace and waterheater valves with a dark orangy grease.
We were able to clean them all with paint thinner solvent.
Our propane supplier explained that when that tank had been filled, years before that
heavier compounds were allowed as a part of LP gas, however when it was used in cold weather, those heavy components condensed in the lower pressure side of the regulator. Thus 'waxing'
Modern refining of LP gas is pure. c3h8
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Jan 01, 2026
