Ronnyjoe50's avatar
Ronnyjoe50
Propane feed question
Hi, & would appreciate any help here. I have a 4 outlet propane manifold under my RV. It has a supply line coming directly from regulator valve off of Propane tank which then threads into the top of manifold & then 4 lines coming out to provide propane to appliances. At the bottom of the manifold there was a plug so I removed it to install my line to feed my outside grill. (I removed the valve from my small drill as well) I have no propane coming out my hose so can only assume the bottom threaded hole I used for supply line doesn't actually serve as another outlet feed line.? Thx anyone who has more knowledge on these manifolds than I do. I have a pic of it but don't know how to download here.
