Wrong_Lane
Nov 29, 2013Explorer
They make wood pellet stoves that vent through sidewalls (no chimney) and are "zero" clearence. If you had some spare room I quess it could work but --- the cost of the extra engine fuel used hauling a load of wood pellets around plus the weight of the stove would likely exceed the cost of LP used in your furnace.
If you were in one spot all winter and had no alternate engery source then maybe but that might be the only time it would make sense.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
