GordonThree's avatar
GordonThree
About to drill a hole
I've been driveway camping for the past week, due to extreme humidity in the area. I've been emptying the 2 gallon bucket on my dehumidifier twice daily, and I'm very tempted to poke a hole in the floor for a drain line.
I think I'd rather drain it to the ground rather than install a lift pump to push the water into the gray tank.
I seldom stay in campgrounds where someone might be offended by water draining from my camper, despite it being "clean" water. If I am somewhere where someone might be offended, I can always disconnect the hose and go back to using the bucket. Then they can be offended by me dumping large buckets of water out the window instead of a slow drip.
I have an enclosed underbelly, which I don't plan to remove for this procedure. I'll cut through the fabric with the drill bit, or a knife, and then caulk around the hose from the inside.
Should I do something to attach the underbelly to the hose? It looks like Elkhart used sprayfoam to attach the other penetrations to the cloth, I don't really see what purpose that serves.
What else an I not planning for?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
