donn0128
Aug 24, 2018Explorer II
As long as what you want to replace is not one of those cruddy priporatory things, then any self power thermostat should work well. I used a battery powered Hunter Douglas with great results. 25 dollars from WalMart. Much better that the wild swing one that came,from the mfg.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
