wildtoad
Jul 09, 2022Explorer II
Once I bought a used MH and the po had replaced bathroom skylight with a flat piece of plastic/acrylic. As I recall they had build a frame to raise the sheet off the roof just a bit. I think the reason was to allow for the headroom lost when you remove the inner and outer bubble. May not be a problem if skylight is not in the shower. What are your plans to dress up the hole on the inside.
I think “curb” should read “curve”. I’m not sure it matters as I don’t believe the bubbles have a curved bottom.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
