SDcampowneroper
Jul 11, 2022Explorer
Dicor sealant either self leveling or not should work well, depending on your fit should work. You might consider Eternabond tape if you cant get a flat fit.
You mentioned machining the edges, you should be able to do that with a router with a chamfer bit, poly thakes that easy, acrylic would crack.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 22, 2026
