cannesdo
Jul 11, 2022Explorer
SDcampowneroperator wrote:
Dicor sealant either self leveling or not should work well, depending on your fit should work. You might consider Eternabond tape if you cant get a flat fit.
You mentioned machining the edges, you should be able to do that with a router with a chamfer bit, poly thakes that easy, acrylic would crack.
Great, thanks...I may take it to a machine shop tomorrow. Just a 1/4" wide 1/8" high lip for the caulk would help to get a clean look I think...I got plexiglass. Did some googling. That looks like it can be routed too -- yes?
I may skip the original framing for the bubble. It's so messed up. Doesn't look great. The screws should hold it tight. I think I'll also paint about an inch at the edge the color of the roof to conceal the butyl (?) tape/putty that will go underneath. I may drill new holes near the old ones for the good fit. Drill right through the plexiglass and the roof at the same time to make sure they line up. Thoughts on that?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 22, 2026
