4x4van
Jul 19, 2022Explorer III
If it were me, and I was installing a flat plate, I wouldn't use screws at all. Holes and screws just create a location for cracks/leaks. I'd simply cut the polycarbonate at least 1-2" larger than the hole, lay down a heavy bead of Dicor, lay the sheet on top, and then add more Dicor around the outside once the initial Dicor dries.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 22, 2026
