diverdennis's avatar
diverdennis
Added Digital 12 Volt Meter
Wanted to be able to check the condition of the house battery and converter output so we installed a digital volt meter. Mounted it on the 12 volt control panel and used the 'Docking Light' switch to turn it on.
There's a bunch of them on eBay for $10
Dennis & Beth
Dewit, MI
Converter Float Voltage
  • DrewE's avatar
    DrewE
    Explorer III
    bbaker2001 wrote:
    would the 50 amp be sufficient . I don't think I ever pull 50 amps at 1 time
    does the shunt just attach between the ground going to battery
    The shunt typically does go between the ground and the battery. All loads should connect (directly or indirectly) through the shunt if you wish to measure the current they consume—so typically the connection between the shunt and the battery should be the only connection to the negative battery terminal.
    50A would generally be adequate for the house loads of a good many RVs, possibly excepting a few things that you may or may not have or care about measuring: a largish inverter (over, say, 250W, when used in combination with other house loads); the starter motor for a generator (my Onan 4KW starter rates at somewhere around 90A), and possibly charging if you have a sufficiently beefy converter or a very good charging setup from the alternator of a motorhome and the battery is sufficiently discharged.
    Many of these digital ammeters are only capable of measuring current in one direction, so you have to choose between showing discharge current or charge current. (This is determined by which way you hook the sense wires up to the shunt.) Some are capable of bidirectional measurement, perhaps only if they have an isolated power supply for the meter electronics.
  • see articles at http://www.pbase.com/mainecruising/battery_monitor for information on battery monitors. i found his information useful.
  • would the 50 amp be sufficient . I don't think I ever pull 50 amps at 1 time
  • i have a victron bmv-700 coming (frequently used in boating) to do the amp/volt monitoring. the nice rhing about the victron is the shunt has some electronics to assist in the amp monitoring such that the monitor wire is a simple ohone jack connection at borh ends.
  • Ivylog's avatar
    Ivylog
    Explorer III
    For $10 I'd buy a Volt/50 amp meter like THIS or for $12 one good for 200 amps. They also come with a 100 amp shunt so you can monitor more than just volts.
    This is how I know my 21 cu ft residential refrigerator uses 8 amps DC when running... 100 watts.
  • We went the more expensive route, a Trimetric, but then wanted to monitor the solar system and batteries a lot closer.
