scrubjaysnest's avatar
May 10, 2015
Adding 12 volt outlets
This is pretty straight forward, usual warnings apply. Check clearances, insulate wire areas that may rub, use proper crimp technique, and fuse/breaker correctly.
Pulling the wire.
Expanding for jumpers.
Heat shrink.
Connecting up. Make sure all slip ons are tight, loose connection is a fire hazard.
Done.
  • I'm in the process of adding a few more myself this month. I like your sockets better than the ones I'm about to use. Where did u get them and how much?
  • The power goes to the socket on our right and the other wires are jumpers to the other socket.
  • scrubjaysnest wrote:
    insult wire areas that may rub
    Shame them into not rubbing! :)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Mar 08, 2026
