deltabravo's avatar
Jan 01, 2021
Adding a new 120 vac circuit and outlet
In my last several RVs, I've installed a new, dedicated circuit and outlet for a space heater.
It's not often that I have electric hookups, but when I do, I use the space heater for heat. I don't camp when the weather is below freezing, so there's no need to run the propane furnace to circulate warm air around the holding tanks. In this scenario, a small space heater is all I use.
Both were easy upgrades because the new outlet location is close to the electrical panel with easy access to everything.
This video shows how I did it in my Arctic Fox 992 truck camper,
  • BarneyS wrote:
    Here is how I did it for our trailer.
    Barney
    That's a really good idea too, then you can run it from the other outlet on the power pedestal.
  • I have have found no trouble running my electric space heater from an existing outlet continuously for days on end.
    Although I generally keep the fridge and water set to propane.
  • I agree with Lwiddis. I learned the hard way not to pull everything through the 30 amp RV plug. A separate extension fished out through the slide seal and back to the pedestal solved the problem. Good job on the wiring and outlet though.
  • “When I'm on a 30A pedestal and need the heater I run an extension cord to an available pedestal plug.”
    This is my plan.
  • Mine new circuit starts with a storage area plug on a unused circuit. It has 2 drops and both are located inside of a cabinet for easy space heater use and storage. Back to the plug in the storage area where the new circuit uses a standard male plug. When I'm on a 30A pedestal and need the heater I run an extension cord to an available pedestal plug.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
