patriot1965's avatar
patriot1965
Solved
Electrical outlet issues
Hello all. Newcomer here. I have an electrical issue. I just purchased a Forest River Cardinal 3825FL. I had a couple guys helping me get it set up, plugged in, etc. To make a long story short, I discovered that 220v has been ran through 110v outlets, causing my refrigerator and microwave to be fried. Now when I test the rest of the outlets I am getting a reading of 110 AND 220. Being a complete novice regarding wiring and electricity, I don't even know where to start!
  • To start, would be to disconnect the improper power source. Next, you'll need a qualified electrician to check/repair all electrical in your coach, to ensure all is safe for future use. You mentioned several appliances were toast, and you're likely correct. All needs to be checked!
    You are not the first, that this happened to. It is not good. but can be repaired.
  • About 99 % certainty, the plug your coach has been plugged into is wired wrong.
    • patriot1965's avatar
      patriot1965
      Ah....that makes sense. Thank you so much for your help!
  • Is it 30A or 50A? Often the 30A RV receptacle gets wired incorrectly for 240V
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
