Acampingwewillg's avatar
Acampingwewillg
Explorer II
Feb 25, 2016
Adding an Air conditioner...as in a third?
OK....so I have two older Carrier 15000 BTU units on my Vogue, these two replaced two Coleman 13,500 units that were standard equip. My front Carrier just doesn't have the output anymore and "ices" fairly easily, ( I keep the fin's and filters clean, I think it's more the fan speed has diminished). When the two units were working flawlessly, in a stationary position, I could actually get it "Cold" inside during extremely hot days...over 110 degree's, but while driving in such weather, very difficult to cool the driving compartment. (Dash air on my MH has been looked at but for the price of replacing the whole "old" system, it's less expensive to go with roof air...that's a whole different conversation).
Anyways back to my question....has anyone here actually put in a third roof air where no provision has been made for such. I'm not one of those who is frightened by cutting holes in my fiberglass roof and I do have an empty 20 amp breaker in my MH panel. the Carriers and Coleman unit were in the 100+/- pound category, the Brish Airs II are about 74 pounds. I walk on my roof all the time and I'm 250 lbs so weight bearing shouldn't be an issue.
I know this is getting long winded but my thought is to replace my front Carrier(the one at issue) with either a Coleman or Brisk Air 15000 BTU unit and then add the third Brisk Air forward of the other one so to offer more cooling up front while driving and for those really Hot days while stationary. As stated, not worried about how to wire it or worried about cutting into it other than hitting some type of super structure in the roof(steel framing). If it becomes evident this isn't an option, I'm sure I'll be OK with just a well functioning replacement....so let me have your thoughts.
PS...I have at times used a portable air to supplement cooling during those times when the roof unit in question has preformed poorly.) Thanks all for reading my Novel...LOL
  • My rear Carrier is still doing well, it hasn't seen the same usage as the front. I do have another option on placement, that would be to put the third unit into the opening where I now have a "Kool-o-Matic" vent(those rather large vents some older MH's have)...I'd still have the vent in the bathroom. this option would be easier all around But my main reason for not liking this is that this vent opening is not centered east to west on the MH(in other words, it would be offset from the other two) but placement would be about in in the middle N/S wise.
  • GordonThree wrote:
    How about adding a "mini split" or ductless ac unit, like those wall-mount kind of LG, Sanyo? You'll only need a small ~2" hole for the refrigerant and power lines.
    Where is he going to put the other half of the unit?
    why not just replace both in the RV?
  • How about adding a "mini split" or ductless ac unit, like those wall-mount kind of LG, Sanyo? You'll only need a small ~2" hole for the refrigerant and power lines.
