westend
Feb 19, 2018Explorer
MrWizard wrote:
when going 'solar' and limiting generator run time
you need enough battery to make thru the night, lights , TV, Heater, device charging, and stay above 50% SOC
and enough solar to replace that use, while ALSO powering your daytime use, water pump , laptop etc..
X2, first step is to understand your total power needs. Tally up everything you will power.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
