Bobbo
Mar 05, 2015Explorer III
I would use taped wire nuts. A 12v circuit, you don't need a box.
Remember that an 1156 bulb pulls about 2 amps each. If you get too many bulbs on that curcuit, all turned on at the same time, you can blow the fuse. If you are using LED lights, disregard this warning.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
