DutchmenSport
Mar 05, 2015Explorer
I added lights in my previous camper. I stripped back the plastic coating on the wire and just used a simple wire nut. Then taped the nut and the wire with electrical rubber tape. I didn't have to cut the original wire at all. You can also use those crimping connectors, where you don't even need to strip back the rubber on the wire. They work very well too.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
