Johno02
Mar 15, 2015Explorer
Sounds like a good idea, only thing is to consider using LED lights instead of the incadecent ones. They are much cooler, and use a lot less current. I am not co concerned about the current usage as I am about the hot bulbs, as I have seen several fixtures and wiring turned black from the heat. I just replaced one fixture with LED strips from IKEA, which was a simple fix and inexpensive also. Previously in you bedside lights, I replaced the bulbs with LED bulbs, but am not too pleased with the ones I got. I think there are better ones on the market now, so I try to keep an eye on what is available.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
