smkettner wrote:
Just connect all the batteries in parallel and charge away. Multiple charging sources is not an issue but I think you need more solar. If you must charge from the generator verify you have a good system charging at 14.4+ volts.
I do plan on getting more solar, but since I just bought the RV, budget is low ;)
In my experience with batteries, I have always been told it is bad to connect batteries of different AH rating, is that not the case in this situation?
Also, if they are all in parallel, do I just hook up the solar charger right to them with all the other charger sources going in and it wont be a problem?
