nremtp143
Sep 12, 2013Explorer
harmanrk wrote:nremtp143 wrote:
Mine are 6" tubes and I love this mod. I have seen a few 8" pipes and one 12" one just behind the front legs done as well.
Thats the one I was looking for.
Looks to be a few bolts through the frame to hold the unistrut in place. What holds the hangers in place, to prevent them from sliding fornt to back? Also, are the hangers something that can be found at Lowes, or Home Depot, or more of a special order item?
Thank you.
Sorry, been away for a couple of days. I found the struts on Ebay believe it or not. However most of your bigger plumbing/electrical supply houses will carry up around 6". Mine are 6" ones. None of the BIG bix stores will have anything over 4". As far as the tubes sliding, when you tighten the bolt at the bottom shown here:
The hangars tighten against the strut and around the pipe. There is no way it is going to move by itself unless you have the wrong sized hangars. The larger sized ones like 8" and 12" will have to be ordered I would guess.
Monty
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
