profdant139's avatar
profdant139
Explorer III
Jun 20, 2018
Aluminum replacement for broken T handle on tank valve rod
On a recent trip, part of the plastic T handle on my black tank valve rod snapped off while we were dumping the tank. Back home, after a little research, I discovered that the T handle was internally threaded and screws right onto the end of the valve rod -- very convenient! So I came up with this simple fix.
(I know what you are thinking -- why not just buy a new plastic handle? I could, but I no longer trust those handles not to break at a crucial moment. I wanted a heavy duty handle.)
I took a piece of half-inch thick aluminum scrap and used a hacksaw to cut a replacement handle. I then shaped it with a flat file and then cleaned up all of the rough edges with a belt sander.
Next, I drilled a 15/64 inch hole in the center of the piece, starting with an eighth inch bit, then a 3/16, and finally a 15/64 bit. (Don't use a quarter inch bit -- the cutting threads on the tap will have nothing to cut if the hole is too big.) I then used a quarter-inch 20 pitch tap in order to create internal threads in that hole, to match the threads on the end of the rod.
I screwed the replacement handle onto the rod, holding back on the rod with a vice grips so I could get it very tight. The end of the threaded part of the rod projected out from the backside of the replacement handle by about 3/8 of an inch. I put a lock nut onto that little stub and tightened it, so that the new handle will not unscrew from the rod.
Here are two views of the finished product. This is a three-quarter end view:
Click For Full-Size Image.
And this is a side view:
  • Dutch, nice MacGyvering!! Let's all admit it -- anyone reading this particular forum is the kind of person who is secretly a little glad when something breaks and we have to figure out some quick and clever temporary solution using junk from the bottom of the toolbox, much to the amazement of our significant others.
    This is not just DIY -- it is DIY as a type of improvisational performance art!
  • I once rigged a temporary fix for a broken waste valve T-handle using two nuts and a large fender washer from my spare hardware collection. Not quite as easy on the fingers as a correct handle, but it worked well enough until a proper replacement was available.
  • Thanks for the tips! I had never heard of 80/20, and I did not know that there are good-looking aluminum handles commercially available.
    But then again, my trailer consists of a lot of DIY parts and replacements, so I would not want to disrupt my decorating scheme. ;)
  • LarryJM wrote:
    You can also buy ready made metal replacement handles for a more OEM look.
    Larry
    x2 ... That's what I did when our plastic T-handles started to break, bought three metal, appear to be aluminum ones. No problems since.
    Clicky here
  • You can also buy ready made metal replacement handles for a more OEM look.
    Larry
  • Attaboy! Being able to work metal is a great skill to have, that aluminum handle should outlast both of us.
    Do you know about 80/20 metals ? They have all different bits of extrusions, the fasteners, etc. They also have an E Bay presence where prices are lower but quality is like new. I use a fair bit of extrusions to build aluminum electronic cases. The end holes are a perfect size for 1/4-20 threads so a builder can jam something up pretty quick.
