SidecarFlip's avatar
SidecarFlip
Explorer III
Jan 08, 2018
Another 'right' tool
I do my own brakes and have for years on my truck and trailers. One of the sticking points I've found is breaking loose rust seized on brake rotors on disc brakes.
No amount of beating or heating seems to loosen them (at least in my case) and I've had to resort to using a 5 pound sledge and serious beating to get them off (at the expense of suspension parts until now that is..
A good friend of mine who is a professional mechanic by trade pointed me toward his method and it works like a charm
I bought a Harbor Freight 12 ton hydraulic puller (70 bucks at HF). It's jaws fit over any disc (fit my F350 discs with room to spare) and you set it up (3 jaws on the disc), align the body with the center of the hub, run it in tight, apply a squirt of penetrant to the hub and 3 strokes of the hydraulic cylinder and the disc pops right off, easy as pie. Great tool and saves a lot of grief. It actually has enough hydraulic force to break a disc off the hub if you want to do that but with me, they popped right off. Sure made a miserable job a cake walk.
Little FYI for those of you that do their own maintenance, like me.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
