RoyB
Apr 12, 2014Explorer III
Your ROADTREK does not have a very large area to mount solar panels.
Keep in mind that what ever you pull from your batteries you have to put back in. The 100W type SOLAR panels only give you around 5-6AMPS DC CURRENT during high sun to charge your batteries with. A couple of panels is not going to produce much more than 10-12AMPS DC CURRENT so this relates to taking a long time to get your batteries charged back up to their 90% charge state before you can use them again at almost full performance. You will run out of usuable HIGH SUN with only 5-6 hours time during the day.
Your question is going to be will 12AMPS replace the power I pulled out of the bank bank before it gets dark on you.
Need to do some reading up on how solar works for you. Your SOLAR CONTROLLER will perform much like your on-board CONVERTER/CHARGER. If you are expecting to re-charge your batteries in a three hour time frame like you can do with shore power/generator running your on-board smart mode converter/charger than many 120WATT Solar Panels will be required to get the right amount of DC CURRENT to satisify your battery bank demands when they are hit with 14.4VDC Boost charge volatges. The rule of thumb is 15-18AMP per 12VDC (typical 110AH type) Batteries in your battery bank. I am not amiliar with your present batteries being used. If your batteries are always up in charge most of the time then the couple of 100WATT solar panels will be great to keep them topped off during the high sun daylight hours.
Will take some looking into to be successful...
Roy Ken
Roy Ken
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
