TUCQUALA's avatar
TUCQUALA
ANOTHER D*** Solar Question!!!!
Just upgraded trailer to a new, much larger trailer (Timber Ridge 280RKS) which has a "huge" 10W Zamp solar panel. The panel is wired directly to the battery through a master switch and 30A breaker. It is not controlled by the disconnect sw.
Obviously, this panel is only for storage maintenance of the batteries, and a draw test shows almost .4 amps of draw on the batts from the many electronics in the trailer. These things are getting like cars with all the spiffy stuff!!
So, my plan is to add a 100-150 watt panel and parallel with the 10 watt. Think I can pull the wires down through the roof pass-thru that is installed and down through the front cap to the junction box under the front crossmember. Probably use 8 ga wire down to a PWM controller to be located in the bedroom and then to the batts.
Comments or condemnations??!!!
Gerry
PS: Can't edit my signature due to a long running problem with the preferences tab!!! Going on 5 weeks now, great IT around here!!!
