jwc99's avatar
jwc99
Another solar question
Didn't want hijack anyone else's thread so here's my question. I was given 2 solar panels to use with my tt. They are Siemens SM55, 55 watt, 17.4 volt, and 3.15 amp each. I will use this setup 1 time a year when I make my Smokey Mountains trip, the only time I primitive camp. I have one 12 v 105 amp hour battery on the trailer. The only power we use in the trailer is for about 15 min of led lighting and each of us a quick shower at night. I would like to use the panels to help with the battery. Since the panels are only capable of 3 amps each would I do better running them separate with a cheaper controller or should I tie them together? I don't want to spend a bunch of money on a controller if possible. What would you recommend?
Thanks
  • a cheap $20>$30 controller from amazon either a 10amp or 20amp PWM controller
    put both panels wired parallel together
  • For 8 nights, with that little use, a good fully-charged battery should last. I'd bring another along just in case.
  • I usually get 2 days out of my battery before I take it off to charge. We stay 8 nights and what I usually do is take the battery off and charge it, I have a plug in my truck that charges the battery as we ride around. I was thinking about buying another battery and adding it to the camper for added support. This will be a portable setup, not something I will mount on the camper.
  • two 55 watt panels.... one battery???
    jeese. Seems to be lots of solar power and not much battery or
    power usage. you need a charge controller so you don't boil your
    batteries is my thinking.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,396 PostsLatest Activity: Nov 18, 2025
