westend
Nov 16, 2013Explorer
Let's see...
A few feet of 1/8" aluminum wire (the bows)
Aluminum rod 1/4" (enough to make the reflectors)
A piece of HDPE (chopped into pieces for stand offs)
1/4" grommets to insulate the reflectors from the center beam
3' or so of 1" X 1" aluminum angle
Two strips of acrylic to hold the top and bottom of the bows
Some 14 AWG wire for connectivity
A balun for connection to coax
Fasteners to put it all together
Some glue for the reflector rod to grommet joint
This is an easy antenna to build and the closer a guy can stay to the critical dimensions, the better the reception. A double array has been touted as receiving signal from 90 mi. There is a whole crowd of antenna nerds that have taken the design and improved upon it. More information is available at the OTA forum.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
